| Message |
I removed the 6 tranny x-member mount bolts, loosened the motor mounts, lowered the tranny, removed the DS back plate coupler and popped it in place (@ rear diff union). Then proceeded to wiggle and wedge it into place with grease all over the place...and voilla' I quickly grabbed the bolts, rotated the DS to line up w/ the holes and began to hand tighten them into place. As a first timer, the lesson learned is to install your DS [before] you mount the tranny x-member etc. Well, I'm off to finishing up this project =:o and thanks for the tip.
